looking to get some help for my 59 sportwin 10hp
HighTrim
Where did you get them from? What part number did you order. They could be for 1 over.
HighTrim
yeah 378425 are rings for when you bore .040 over. NOT for standard pistons sorry they will not work.
Trooperx99
oh well that sucks, i knew 8 bucks was too good to be true, thanks for the info! im sure ill be back to post more questions.
Trooperx99
hopefully this is the last set of questions i have, BUT is there a right and wrong way to install the piston rods to the pistons? one side is flat the other open, also are there torque specs for the nuts that join the powerhead to the exhaust housing?
Trooperx99
also is there a "close enough" when installing the rod cap, they sit pretty flush but i can catch my fingernail just barely on the inside, cant feel it with my finger though.
HighTrim
Make sure the rod caps are the correct ones for that rod. They MUST go with the one they came from, and MUST go in the same direction. Some have a small dot to line them up. As you tighten them, rock them slowly.
Obviously you know which way the piston must go in the cylinder. That is important! Swooping side towards the exhaust, short steep side to intake.
Then, if the rods have oiling holes, they face up.
If the crank has counterweights, the rods will only fit one way.
Flat side of the rod faces the center main bearing.
Trooperx99
again another question, how many needles am i supposed to have, i have 29 for each rod on the crank, but that leaves space between them, is this normal?
Trooperx99
nevermind the crank wasnt pressed against the rod good enough, tomorrow putting on the stator and flywheel, and hopefully the rest of it if i have the time and its not sweltering in the garage
