TRUE GRIT
- Aug 1, 2009
- 14
hi all;
I have got a 2002 w/a - year 2000 & I'd like to swap the current pedestal for the passenger seat and install a shelf unit running from inside the port side cockpit w/ rail legs for support so as to be able to store a cooler under it and re attach the current seat to sit atop and maybe even a small cushion behind it as it could be used as a jump seat facing the rear. Looked on ebay with no luck, any and all help will be appreciated including photos if you have a similar set up Thanks
