_getsideways_
Thread starter- Joined
- Aug 4, 2015
- 3
Hello all thanks for the help in advance. I bought my first real boat this year, after contacting the sand bottom at a local lake that we will never go back to I slightly flared the tips of the one and only prop on the boat. From what I've read SS is the way to go, My current prop is not that bad but I want 2 on the boat at all times.
I'm looking to improve upon overall performance without loosing top end or cruising speed.
We do a lot of cruising and double tubing, very little wake boarding or skiing,
2003 260hp 5.0 MPI Mercruiser 1.62 alpha drive
2003 Larson 210 LXI 20' 6'' 29xx Dry weight
Current prop is a 14.25 21P Aluminum 3 blade mercury prop
4900 RPM 52mph 2 adults, 4800 RPM 49MPH 4 adults fighting a river current, clean water conditions very little chop, speeds are off the factory gauge.
Boat has a wake tower, and no trim tabs or any other major weight or performance modifications.
I can cruise at 24-30 MPH at 3000RPM depending on how loaded we are and trim settings.
Hole shot is good enough unless we are fully loaded then it suffers a little.
Ideally If i could keep the top end that i currently have and add a better holeshot and lower planing ability I would gladly take it.
