Looking for top mount trottle control for older Johnson outboard
gil_happy
Hello,
I need some advice regarding my 1983 (I think) Johnson 90HP outboard engine. I'm looking to replace the factory, side-mount throttle with a new top-mount throttle / binnacle.
Does anyone have any suggestions to an inexpensive top-mount throttle control with cables that will work for an older Johnson outboard?
Any suggestions, such as manufacturers, etc are greatly appreciated!
Thanks in advance
hidef
Re: Looking for top mount trottle control for older Johnson outboard
You can order a top mount control right from iboats you will also have to order new control cables if you go with an aftermarket control. You could also order a top mount from BRP but they will be pricey. If you go to a top mount you will have to pull the wiring and switch out of your existing controls and mount it in you dash.
