Looking for Titan Model 60 rebuilt kit - 1" piston
Homerr
I am looking for a Titan/Dico model 60 master cylinder rebuild kit. The number on the bottom of the master cylinder is 23361 and it has the 1" piston.
Apparently they changed to an 1-1/4" piston some time ago, so finding the 1" kit has been (so far) unsuccessful. The kit part # is 068-032-00 or 1502600.
Any idea where I can find a kit? I'm hoping there's some old stock somewhere collecting dust?
I really don't want to buy another master cylinder when all I need are a few cheap seals!
Thanks,
dingbat
Thanks,
The model 60/660 is a rebadged Tiedown unit.
The actuator was a “disposable” $129 unit back in the day. I think I paid $109 for mine.
The original docs don’t list nor offer a rebuild kit for the master cylinder. A new master was something like $60.
The model 60 was updated and rebadge in 2012. Any “old stock” kits would be well beyond their life expectancy. I certainly would use one
If your intent, tear it down, size and source the replacements yourself. No rock science involved in oring sizing.
bruceb58
Honorary Supreme Mariner
It is not a rebadged Tiedown unit. Its still a Titan Dico unit. I know because I just abought a few of them for my trailer and for others. https://smile.amazon.com/TITAN-DICO...o+model+60&qid=1625695656&s=automotive&sr=1-4
They have replacement master cylinders for these.
Here is the drum version
The 1" master cylinders are obsolete. They are all bigger than that now as you have found. Personally, rebuilding a master cylinder, especially a trailer master cylinder is an exercise in futility.
dingbat
You are correct.
Dexter is stil marketing the old Tiedown model 66/660 under the Dexter name
dingbat
Hopefully people realize it's still the POS Tiedown.
Whats the story behind your hard-on with Tiedown?
Their brakes are useless but I’ve had good luck with my model 66 actuator as had a number of other people I know who run them.
I went that direction solely on the fact that the master cylinder is aluminum. Saved me from replacing rusted out master cylinders every couple of years.
It solved a problem and I’m good with that. A 15-16 year old actuator that cost me $129 owes me nothing.
bruceb58
Where should I start:
1) Disc brake rotors that warped...every single one of them
2) Disk brake calipers that seize
3) Lug studs that snap even when using a torque wrench to tighten to spec.
4) Brake master cylinder that leaks after 3 year.
Replaced their disc brakes with Kodiak..no problems for years now
Replaced their crappy surge actuator with Dico...no issues now.
Homerr
Thanks for the replies! I did manage to finally locate a rebuild kit for the 1" master cylinder. It's all back together and works great. I saved about 50% - 60% over the cost of a new master cylinder. I doubt I'll be able to get away with this next time, so I'll upgrade to the 1-1/4" when I have to. Heck, I may even play around with it after it wears out again and chuck it up in my Bridgeport mill and bore it out. If I mess it up - oh well - it would be fun trying (yes - us old machinist get bored too... lol). You can readily get the 1-1/4 kits.
I also rebuilt both wheel cylinders. Cost was about $5 per side. Normally I'd just buy new ones, but the cylinders are in excellent shape except the boots - they were cracked from sitting for so many years. The bores are perfect and not a scratch on them (and the only reason I rebuilt them). So in the end, I saved about $40 - $60.
As I can't stand paying dealer markup prices (who does?), I always try to cut the 'middle-man' and find WHO makes our parts. In this case: our brake parts. Both my master and wheel cylinder rebuild kits came in boxes labeled: "TCIC" (Tae Chul Industrial Co.). Korean I believe. I'm not sure if they sell direct. Probably not.
if your that tight that you cant replace the whole master cylinder on a boat trailer, boating is not a hobby for you.
I wouldnt trust 10 year old korean made rubber bits
wheel cylinders come on loaded backing plates. I think the last time I paid under $100 for new backing plates, all hardware, wheel cylinders, etc.
Homerr
I've been boating for 30 years and it's not a matter of being 'tight'. I just don't like being ripped off and I don't mind getting my hands dirty.
That's the problem with today.. people are too damned lazy and would rather replace it than fix it.
Im all for fixing things that can be fixed. however for trailer brake parts, I would not trust 10 year old rubber bits.
