BillWilliams
- May 23, 2021
- 76
I'm in the process of repairing a transom assembly leak which includes of course replacing rotted plywood (I'm going with some Coosa board). Anyway, in preparation of re-installing the transom assembly, I was hoping to pick up on some tips and/or tricks from the good folks here.
I figure it's not important, but the transom assembly serial number of 0L529806.
I found instructions that say I need to use a 1 3/4 inch hole saw to cut the reliefs at 60 degrees for the tiller arm to move back and forth and to drill the holes for the studs at 9/16.
I've also seen suggestions here to use bellows adhesive to first mount the gasket to get it to stay in place on the assembly.
Anything else would be greatly appreciated.
Thanks
Thanks
