- Mar 8, 2009
- 44,793
When I remodeled the great room I installed some 50 watt halogen blubs. Well they are dimmable, put out plenty of light turned almost all the way, but didn't think of it at the time, they also get hot. So hot that in the pick you can see where they are starting to discolor the paint. Need to do some touch up on the drywall tape in a couple spots and would like to find some LED's to replace them with.
The box beam is 6x6 and the lights are the ones that are originally design for under the counter at 3.5 diameter. There are six of them facing toward each other from opposite sides of the room
Have looked at track lighting fixtures which I could take apart and install direct with some kind of flashing. Looked at dome which had 2 lights sticking out, but nothing looks right. Would like to find something that would be a bit bigger around, maybe oblong.
