Looking for another Prop
Bonker43
I have a 115 Mercury 4 stroke on my Trophy 1802 and am looking for a new prop and use my existing one for a spare. I mostly fish and do a little tubing. Any suggestions? Thanks.
steelespike
Re: Looking for another Prop
Welcome,
There is a form at the top of the page that will aid prop selection.Also if you read the stickies at the top of the page and the helps at the prop store page it will help you better understand prop selection.Your request seems simple enough so if you give us your prop size(on the barrel or under the prop nut)and your present max rpm and speed(gps is best).Also how it seems to perform now and what you would like to gain;we can probably help with a prop selection.
Yup -- without some base-line test numbers you don't know if the prop you currently have is correct, much less which one you should buy. Make several test runs at wide open throttle with what you consider an average load. Note engine rpm and observed speed. Without those numbers we can't help much.
