Re: Looking for a good Cold Smoke Recipe
I found this one.<br /><br />For 5-10 lb salmon, clean and split. Make slash cuts 1/4-1/2" deep on the bias in the skin sides. Weigh out pickling salt (non-iodized) equal to 15% of the fish weight and divide it into two proportionate piles. Rub the salt well into the upper 2/3s of each side but none on the lower 1/3 tail section.<br /><br />Run a stout cord or dowel through the shoulders of each side and hang in a well ventilated, cool, dry place for 2-3 hours. Rinse well under running water to remove all salt.<br /><br />At this point, seasonings may be added in a powder form or in a flavored alcohol mixture. Some seasonings used are garlic, onion, mustard seed, bay leaf, coriander, cardamon, cloves, mace, alspice, fennel, dill, etc. Vodka & optional seasonings may be rubbed on to the fish prior to smoking and after the salt has been removed.<br /><br />The fish is hung again in the well ventilated, cool, dry place, until a shiny surface is formed.<br /><br />Next the fish is exposed to a rather dense smoke of oak, hickory, apple, (some europeans even use use a little juniper) at temperatures not exceeding 90 degrees. The smoking should continue for at least 36 hours and may, in Finland where it may kept for several months) be smoked up to 3 weeks.<br /><br />Smoking need not be continuous during the whole period, but a 70-90 temperature should be maintained. Fish prepared this way should have a firm yet flexible flesh that can be cut on the bias in sections thin enough to read through. It will keep in the 'fridge for months, but it never lasts that long. Good to seal in plastic bags. Evacuat all the air. But that is a waste of time. It all gets eaten very quickly.<br /><br />This must be done in a smoker. If you don't have a smoker, you can convert a 30 cu. foot, upright freezer into a smoker. The racks are stainless steel. Supply the smoke through 3" conduit from a brick smoke pit 20 ft. away. Mount a thermometer through the front door.
