Looking for 1990 3.0 exhaust manifold
Peter123!
looking for a exhaust manifold for a omc 3.0 in a 1990 four winns.
alldodge
Google "omc 3.0 exhaust manifold"
Or look for BARR-OMC-1-3858850
alldodge
OK delete post, it was for 1995 and newer will look some more
Peter123!
Again the Intake runners are different. Thanks for searching though
Peter123!
Look at the pictures I posted and you will see the difference in the intake runners. It will not work
alldodge
It is a unicorn, but just maybe Lou's will work, or maybe even a different one if thought about it just a little more. Yours in one of a kind, I cannot even find it on the web with a part number. But if we look at what is actually needed, only the outside area needs to seal. The ports are in the same orentation.
So maybe worth buying one gasket for the newer manifold, and see if the gasket will cover the other edge. If it does, then cut away the inside
Peter123!
This is what I ended up going with. It does have the Holley carb so if the intake runners will work I should be good to go. I hate to put a lot of money in it. I’m going to sell it since I’ve only had it out twice in two years 😂
Lou C
It looks like they were trying to find a way to make it cheaper to cast, leaving the divider out between the center exhaust ports and the same for the intake ports. As long as the ports match up with what your cyl head has, it should work.
https://www.michiganmotorz.com/marine-engine-1990-current-p-69.html
look at the ports on the cyl head of this 3.0. Are they the same as what you have?
