Long shaft to short shaft
gazzatop
Hello
Hope some one can help me I have a short shaft engine on my boat that is playing up , I have been offered a
20 hp Johnson long shaft outboard engine . . it has , I have been told, a expansion section in it that is removed would make it short shaft.
I am not sure of the year of the engine but we think it?s a 70s- early 80s model.
Can any one tell me if it is easy to change the shaft length
thanks
Gary
gazzatop
Re: Long shaft to short shaft
Hi
thanks for the quick reply , checked out the link , the only problem is at the back of my boat its not stright it has a drop down bit(not sure what you call it ) would this still work ?
MikDee
Banned
I converted my Dad's 1962 Evinrude 40hp bigtwin short shaft to a long shaft, with a factory shaft extension kit, about 40yrs ago, it was quick and easy, and I was not very mechanically inclined back then. I don't know if the process is the same on your later model motor, but If it is anything like that, it's no problem, But try to get a definite answer if it is before you do it.
reload
It is not a big deal to convert, but I think what the op is talking about is that the motor came with the expansion built in. I am aware of the motor but don't know exactly what year it was started. I'm pretty certain the 1985's have it, not sure about earlier years.
gazzatop
thanks for the replies , i am going to have a look at the engine again tonight , can any one tell me where i look on the engine to fine the details as to the year , and model number ????
reload
Post the model and seriel numbers on here and someone will help you out.
gazzatop
Thanks will do that , can any one tell me where i should be looking for the model and engine numbers and what they are like , i have seen some but they look more like the part numbers
darrklim2
Depending on the year there should be a shiny silver plug about the size of a 50 cent piece in the side of the block with numbers stamped in it. Some had the numbers on a tag on the lower cowl under the carb. there are some other locations that I am unsure of.
gazzatop
hi
thanks . i have swaped every thing over and all looks fine . have run the engine in a bin of water and looks like it does what it should , the test will be at the weekend when i take it out i guess . now to try and find the year . i have got the number off the side of the engine C0021689 there is also a M above it if any one can help with the model and year that would be great
thanks
F_R
That is only the serial number. The C means it was assembled in Canada. Otherwise, it doesn't tell us much.
The M is OMC's logo.
gazzatop
ok thanks will check again , that was the number from the silver plug on the engine , i could not see any others but am not to sure where i should be looking
