long hub /short hub
rod-doc
I have a volvo penta 270 outdrive. I currently have a short hub prop which has a spacer with a center lock bolt in the cone. can I remove the spacer and use a long hub prop? The manual is not specific to this..I bought a long hub prop, thinking I had a long hub on it originally,but it is a short hub.Any help would be greatly appreciated..
SleekCraft85
Re: long hub /short hub
in the last month i have lost 1 propeller and 2 cone nut kits while running props without the lock washer. after my experiences i would not recommend running a prop without it, i wouldn't feel safe relying on the torque of the cone and allen screw to hold onto my new prop.
rod-doc
So I guess the answer is no? I can't use the long hub with out the spacer?
SleekCraft85
rod-doc
Thank you for the reply, I measured everything out and I couldn't see why it wouldn't work..It's just that if I put the prop on the boat and it doesn't work, I can't return it.And that's a chunk of change I prefer to be positive about..Thank You
rod-doc
Thank you very much,I appreiciate your responce, i am new to the volvo penta world.And you guys have helped me imensly
