Lock motor in up position
peterbrown77
This is not exactly the correct forum - but it kinda is ....
I have a 1995 9.9 Mercury 2-stroke on my inflatable. It is too heavy for me to keep taking it off/putting it on when I am towing the dinghy behind my sailboat. I want to leave it on, but in choppy water the engine won't stay in the "up" position. When this happens, my dinghy now has a rudder and a mind of its own, so i have to stop the boat, get in the dinghy while I'm bouncing around 5 miles offshore and try to put it back up.
I see that there is a tilt lock kit for trailering the boat that is supposed to keep it in the "up" position no matter what.
The questions/problems are this: first, it is kind of pricey for what it looks like ($150). Second, how quickly can it be locked in the "up" position? Will I be fiddling for 20 minutes and dropping parts in the water?
Finally (and what I really want to know) - has anyone come up with an alternative that is cheap and effective?
TIA
mudslinging79
Re: Lock motor in up position
cut a scrap piece of wood , like a 2x4 and set it across the part where it hinges, under the powergead, play around with placement. weight of the motor will keep the wood in place. cheap and easy
Howard Sterndrive
a heavy rubber bungee cord (not a cheapie) will hold the motor tilted, or will help hold the wood in place if blocking
