livewll timer
jlsmith
When i turn my livewell pump on it works just fine but sometimes when i switch it to auto the timer module just clicks and the pump turns on and off real fast the light on the switch turns on and off as well why does it do this is the module bad. It doesn't do it all the time.
Boatist
Re: livewll timer
If it has a timer try turning some. Turn the control where it is set a little longer or shorter. Sometimes the control bad spot and moving it just a little is all it needs.
