Livewell
nhunt52
I just bought a 2011 Manitou le 200 fish pontoon and see the livewell is not hooked up. The aerator switch on the dash lights up, but thats it. Does anyone know how to get detail description of how to set it up? Thanks , Neil
clemsonfor
I would suggest a multi meter. You need to test if the motor is getting power, will let you know if there is power at the pump, to let you know if pump I'd bad or it's between the pump and switch. Switch could be bad, wire bad, maybe blown fuse. Just start at one end and work to the tank.
pump could have been run without water and burned it up
