Livewell problem - 1978 Cajun fish and ski
Cajun Black 1978
My livewell blows the fuse immediately when turned on. there is one pump but two switches, front and back to fill the two wells. so you can operate it from either location. if you dont need to fill both they each have a valve you can shut off. when i remove the lead off the switch it is shorted to ground. The pump is a couple of years old. I can connect it to the battery directly and it runs fine and does not blow the fuse. when i traced the lead coming off the switch i found that it goes into a terminal block that is encapsulated in epoxy hard as a rock. cant see whats in it. there are a total of five wires going into this thing. i was thinking this may be some sort of module to operate the two switches for the one pump, kind of like a three way in a house. Anyone ever seen one of these or know wht it is? Thanks.
Rob
Silvertip
Honorary Supreme Mariner
Re: Livewell problem - 1978 Cajun fish and ski
Not sure I understand how disconnecting can result in a short. The fuse does blow because there IS a short or a very high current draw somewhere. WHICH lead are you disconnecting from the switch. How is the switch labeled? If there is a MAN and an AUTO setting, the epoxy module you found is very likely the timer for the AUTO setting. If there is a light in the switch, then the ground wire on the switch is ONLY for the internal light. Nothing else should be connected to it. The two switches merely let you operate the pump from up front or at the helm. We really need more detail on what the system looks like.
Cajun Black 1978
Thank you for your reply Silvertip. As far as the short , what I should have said is when I disconnect the lead from the switch AND measure it to ground with a meter it is shorted to ground. This is the positive lead that connects to +12v when the switch is on. This switch is a simple on/off switch. However, in the front of the boat there is a Manual/Auto switch along with the little potentiometer. There are no lights in the switches. Sounds like the epoxy terminal could be for the timer. The leads going into it are hard wired. If this turns out to be the source, are these things still available?
Thanks,
Rob
