Livewell/Bilge pump wiring/installation
PrplGld
Hi guys, I need help figuring out where to make connections for my new livewell pumps. I know nothing about bassboats or livewells. I ripped out the old pumps and wiring but now I'm not sure if that work was original. What are these holes for? Any suggestions are welcome for my upcoming livewell restoration project. This is a 1992 Skeeter SS90 (16' bassboat). Thanks in advance for any help.
I know what the middle/bottom is for. None are for the bilge pump because the port for the bilge pump is located on the starboard side.
(the holes are numbered on the photo, as you can see, for easy reference)
Silvertip
Honorary Supreme Mariner
Re: Livewell/Bilge pump wiring/installation
#1 and #3 are apparently intakes for the livewell fill pumps. The screen on #3 is obviously broken off. #2, #4, and #5 are drains and overflow. What you have in front of all of those is unknown to me since I know nothing about that boat, where the live wells are, how they were/are plumbed etc. Since there are two intakes, I would assume there are two livewells, and each has its own fill pump. The inlet to each pump comes from port #1 and port #3. Each livewell need a drain so two of the ports serve that purpose. What the fifth port is for I have no idea. The lowest port is the bilge drain -- you need a bilge drain plug for that hole or the boat will sink. Pull the plug to drain any water after a day on the water (boat out of the water on a trailer obviously). The fifth port may be an overflow for both live wells IF the livewells don't use a standpipe as an overflow. If that's the system, then you would plug the drain in the bottom of the tank. Pump the tank full, and excess water runs out an overflow at the top of the tank and is routed out one of the drain ports at the rear of the boat. Both overflows could be T'd together. To drain the well, pull the drain plugs.
PrplGld
Thanks for the reply. My next question was going to be about the livewells. There are two (front & back), and each has a lower and upper hole.
I was wondering if the water is pumped into the top and a plug is used for the bottom, but I don't like that because you've got to get wet to refresh the water. Instead, I was assuming that fresh water would be pumped into the bottom hole in each livewell and excess water would drain out of the top. For examle, #1 & #3 are "in" to the top livewell holes and #4 & #6 are "out" of the top livewell holes. I guess I'm looking for confirmation on my suspicions.
Hole #5 is the bilge drain. I really don't know what hole #2 is for.
Silvertip
No -- your system apparently used a standpipe in each live well. If you don't know what a standpipe is, take the lid off the toilet tank in your bathroom. If the tank gets too full, water runs down the standpipe. Your livewells should have a plastic pipe with rubber end on them that merely sticks into the drain. You fill through the top hole. When the tank level reaches the top of the standpipe it simply overflows and runs out the drain. you want to fill from the top as that's what aerates the tank. In fact if there are no spray bars or spray head in those tanks, you should retrofit for better performance. To drain the tank you simply pull the standpipe.
PrplGld
Ah, I see. The rear livewell had one of those. But it was so shabby I threw it out. The front livewell did not have one. Thanks for info.
