Live well
outdorzman
Took the boat out the first time this year. Everything worked fine except when I flipped the switch for the live well...nothing. Power switch on, key on, everything I try I got nothing. Checked all the fuses under the steering wheel. All looked good. Any ideas??
Bonus Check
Start running your lines down. Check to see if you have power to the live well pump. If there is power there then the pump may be bad. If no power at live well, check at the switch. If you have power at the switch and no power at the live well pump, check the wires between the switch and live well for mice marks or shorts. Continue on until you isolate the problem. Can be corroded wires
outdorzman
That's what it was. Had power to switch. Traced wire to pump and a splice was disconnected. Fixed that and pump is back in action!
Thanks
