Live well pump switch
Calworks
I have a boat that has a switch at the bow and one at the console. The pump used too work with either switch, now only the front switch works. I've checked the console switch and it is getting power as shown on the red indicator light, problem is it won't let the pump start. I've checked every fuse under the console and they are all good (used multimeter to check). Any suggestions on what be the cause
gm280
Sounds like either corroded terminals (positive and negative) or a broker wire(s) to the pump. Remove the wires from the console switch and clean them shiny and bright and see if that fixes it. If not you have a broken connection from there to the pump...
