(Pardon the new thread, my current threads topic is not related to this issue and is not generating hits for it. I'm pressed for time to get this done, do to rapidly approaching winter, and 7 day cure time on 5200...)
My Livewell drain and overflow, were poorly installed. I plugged the holes, and am going to redrill, to add proper thru-hulls and seacocks. I am adding Seacocks and Bronze thru-Hulls.... but, I won't be able to redrill through the plugs in the original location, as, they wont fit now that I'm adding seacocks. The drain will be fine. It's the overflow that is the question. Looks like I need to drill a new hole. I'm not sure where to drill the new hole. Here is a look at the drain and over flow. The real question, is, how to proceed with the livewell overflow. Now that I have to drill a new hole, I have new options of where to put it. Do I just make the hole as close to the original as it will fit, or, should I re-locate it, higher on the transom, closer to the water line? Or, anywhere that it fits easily? Or, something else?
YouTube video of it: http://youtu.be/LsF5QmcyM1s
The key question here is:
I plugged the overflow thru-hull of my live well. It ran from the livewell, to the near bottom of the Transom. There is no room to return it to that spot. Now that I will be drilling a new hole, and therefor have the option to CHOOSE where the over flow thru-hull goes.... Where should I put it? As close to the bottom where it was originally, up higher/closer to the water line, wherever the darn thing fits, or... something else? It's a 1-1/4" through hull. So it's not going to be a large hole.
