Live well leak
BtownRick
Hi, I have a 2007 bass tracker pro guide v16 wt. Water leaks into the boat around the drain port beneath the boat...water enters around the port not through the port. I know this because I filled the boat with water yesterday and this is the only place water was exiting. It is an aluminum hull, welded. Trying to figure out how to repair. Do I need to remove the bow deck to access this part? Can a run a bead of silicone caulk around the collar of the port? I tried dealing with Tracker to no avail...they just tell you to take to a dealer, but none are nearby, plus, I am a diy person. Thanks
Msky_Hntr
If it's anything like my Bass Tracker 2 the tube is welded to the hull on the outside, You maybe able to have a welder grind the weld from the outside and weld it back.
BtownRick
Thanks for response, but mine is not welded to hull. It is black plastic. I can't see the inside attachment of this one, but there are two other ports above the water line and they are being held on by a plastic nut. Thanks
Msky_Hntr
Then it's a thru hull connector and probably cracked. Ot it could have a bad gasket and you would probably have to remove the floor to fix it.
