I have an older 1992 Lancer 15' 4" bass boat. It has a very small live well in it but no aerator. Just a hole in the bottom to let water in and also let water out. The hole can also be plugged which is what I have been doing. My problem is that every time I use my boat and bring it home and park it in my driveway, I have water dripping out from around the exterior bottom of the live well hole on to my driveway even though there is no water in the live well. I suspect that I have a leak around the bottom of the live well drain hole and that water is getting into the space between the bottom of the boat and the boat flooring. My question is this how do you replace the brass fitting for the live well that goes through the bottom of the boat. Is it threaded in or pushed in and then flanged out so that it stays in place. There are no hoses on it. It is just brass inside of the hole in the bottom of the live well where the drain plug is inserted. Can the brass fitting be tightened up or does it just need to be replaced with a new one and sealant put around it. Thanking anyone in advance for their response and assistance with this problem.
