Lithium Batteries???
Bubba1235
No longer on Forums
I got mail today from a company called "Jolt" about their new high capacityLithium marine (both deep cell and starting batteries) and if their claims are correct its pretty amazing. How about a starting battery that puts out 1,500 cranking amps and weighs only 10 lbs? Device (tolling motor, etc.) battries that provide three times as long on a charge that lead acid batteries do at the same weight. Both types of batteries can be charged in half the time of lead acid?
Sounds great if the clains are accurate. Um, no, they are not cheap...
bruceb58
Honorary Supreme Mariner
Re: Lithium Batteries???
Also charging them is a completely different system and more expensive.
A friend of mine is building his own electric car(VW Bug) and he is going with lithium. You have to be a lot more careful with them especially with how far you discharge them.
bruceb58
Sounds like this is a ways off. My bet is a year or two at least from this company.
Silvertip
There are all sorts of battery technologies that "for a price" can be applied to the automotive (already taking place) and the marine industry. I have a radio controlled model airplane powered by a Lithium-Polymer battery pack. Lithium-Ion and A123 are a couple more variations. All of these batteries pack a punch but come at a hefty price. Li-Po batteries need to be handled with extreme car as they can explode or catch fire in a heartbeat if punctured, shorted or mishandled. That is why they are stored and charged in a fire retardent bag or contriner. My batteries are stored in a metal container placed inside another metal container. You never put these batteries on a charger and walk away. As often as folks reverse polarity or draw sparks from improper boat wiring or when installing their boat batteries I can see frequent personal injury due to explosion or fire. To give you an idea of the power in these packages, they can be safely discharged at 20, 25, or even 30 times their rated capacity. That makes one awesome arc welder. Treated properly they are a great, but expensive power source. Mishandled they are a bomb waiting to go off.
TerryMSU
Most of what they claim is accurate and within the reach of today's technology. The would be VERY light weight and have minimal self-discharge. I can't say whether the 1500 amp cold cranking is accurate. I also think the charger would need to be different, based on my experience with lithium battery technology. The cost of the charger should probably not need to be much higher. This is the technology that is being used for the new electric vehicles and hybrid electric vehicles, so the technology should be available VERY soon. On the negative side, the auto industry will likely be eating up most of the available supply of the raw materials.
As far as cheap, look at the cost of a high end AGM battery. They are not cheap either. I personally would love a pair of lithium batteries for my boat to cut out about 100 pounds of lead batteries.
TerryMSU
"Li-Po batteries need to be handled with extreme car as they can explode or catch fire in a heartbeat if punctured, shorted or mishandled."
Sounds like something one would want in their boat. :eek:
Silvertip
Mishandled they are equally dangerous. However, people do strange things with electrics and if you do it with a Li-Po battery the results are instantly catastrophic.
You mean like a 100 gallons of gasoline? :D
Yeah, well, gasoline is no where near as easily explosive and Silvertip is correct, "Mishandled they are equally dangerous" still you'd want to limit the chances of fire or explosion. My point being that it is dangerous enough you have gas and regular batteries, why introduce something more dangerous...but you knew that I am sure.
