johnnynegaunee
Thread starter- Joined
- Jul 24, 2007
- 69
I just put in a newer 3.0L Merc. into my '72 Starcraft, greased up the fittings in the outdrive and reattached it. I have the older R drive with the lift ring, anyway it shifted fine in the driveway with the muffs. Then I lifted the drive, drove 3 miles to marina launch, put it in the water, lowered the drive, started the engine and now I only have forward and neutral. Can this era drive linkage be affected by position? I hate to take the outdrive back off if it is not the source of the prob. Is there a clip that holds the cable slider and the little shift lever together there in the housing between the gimbal and the outdrive.
Thanks for your input.
John
John
