linkage issue post carb rebuild 1983 140 Johnson
tbonus56
'83 140 Johnson; Out for first time this season and no top end...was carb. issue...rebuilt carbs and RPMs up and where they should be engaged fwd. and no prop movement and shifter seemed 'stiffer' to shift than normal....sound like linkage issue or something else?
interalian
Post a picture of your linkage setup. You'll need a couple more posts before you can put pix directly here (400kB max filesize).
Johnrudemech
Won't shift into forward and shifter seems stiffer than normal...Remove the cable from the shift linkage on the engine. Start the engine and engage the shifter on the engine by hand to see if it shifts into forward. If it does, the cable or control box is at fault and you need to look there. If not, then the lower unit needs inspection and the linkage under the powerhead for the shifter needs inspection.
