Link & Sync On '03 Johnson 115??
srssrs
Can someone tell me the basic procedure for setting the timing on a late model 4 cyl. Johnson with optical ignition system. Are special tools required such as timing light, etc?
If I were to take this to a good outboard mechanic, what might I expect to pay if timing was the only issue and setting it solved my running problem?
Is "link & sync" a procedure which synchronizes the carbs (ie. setting the butterfly valves so they open exactly the same).
