link n sync 1978 johnson 115
tony1100c
Having trouble wanting to die, done rebuild both carbs and fuel pump, will run fine once going, dont understand.
emdsapmgr
When the engine starts to die, have a buddy got to the back of the boat. Have him constantly prime the fuel hose bulb. This will force extra fuel into the carbs. If the engine runs fine as long as you constantly prime the fuel hose bulb-then you have a fuel problem. It's running lean. If the constant priming does not help, then check the 4 spark plug wires for spark. Keep in mind the lower two cyl spark plug wires are very close to the two lower cowling latches. Weak wires can go to ground on either/both of those latches.
tony1100c
Thank you for the tips, I will try this, I have never thought about plug wire grounding out.
tony1100c
Will run fine going down river all day, only when idling trying to take off, really acts nasty in marina, but it will finally catch up, there is a different reaction sound when does right.
