Hi all, back again for advice.
Background
I have a Wellcraft 175Sx Excel boat equipped with a 4.3GL Volvo Penta engine and SXCobra leg.
When I got the boat the engine was a bit lumpy and running very rich. I've fitted, new plugs, new electronic choke (old one not working). Got her running but seemed to miss and cut out when rev'd. Ive fitted a new coil, new ignition module (distributor cap looks new). I've also checked the timing which is ok by adjusting the distribution. The engine will rev to about 4000 rpm under no load (out of the water). However when under load I can't seam to get it above 3,100 rpm which I get at about 3/4 thottle range. After this there's no chnage on the rev's. There's plenty of fuel going down the carb barrels, plugs look a reasonable colour and its doesn't sound like its pinking or missing
The engine now starts fine.
The prop is new, marked 14 1/4 x 23.
Questions
Should I be able to get more rev's? could the prop be oversized ? if not any thoughts on cause of low revs or is this normal for this engine boat combination ?
My only other thoughts are new HT leads and a carb rebuild kits.
Suggestions/ advice/ help appreciated.
Thanks
Background
Questions
Thanks
