Limber holes?
waynerh
I have a 92 Four Winns horizon 220 and it has only 1 limber hole in the engine mt stringers (only on one side). It is 1" above the hull so water pools above the stringers.
I know I should cut some limber holes in the stringers so the water can drain into the bilge. What size should they be and do they need to be glassed or just resin applied after I cut the holes?
Thanks for your expertise and help.
Wayrh
Coors
Re: Limber holes?
1 inch or so, then smear some epoxy, or resin.
Welcome to 4winns.
erikgreen
Re: Limber holes?
Welcome to 4winns.
What?
Yeah, 1 inch is fine. Water doesn't need much space to flow.
But, seal it twice to make sure it's sealed. You do not want ANY water soaking into the stringers.
Erik
Coors
Re: Limber holes?
What?
Erik
My 88 4winns is missing limber holes, and has some too high....
