Lightwin 3hp carb diagnosis question
boomzilla
Hi, thanks for reading.
I just started working on an old lightwin from the 60s. After blasting out the carb and fiddling with the low and high speed needles I have it to the point where it runs great at wide open throttle. The problem is that it will only start or run at WOT. When I lower the throttle past 3/4 it sputters and dies regardless of low speed needle adjustment.
So right now I'd be thinking it's a clogged passageway and no fuel is moving through the low speed side except that spraying starting fluid down the throat of the carb doesn't do any good. Spraying starting fluid to get the motor to kick over at less than 3/4 throttle doesn't work either. When I try to throttle down It acts more like its flooding and bogging down than leaning out and dying.
I already have a rebuild kit on the way and I figure that will probably fix the problem, but what do you guys think is going on?
boomzilla
Compression 'feels' pretty decent but I haven't borrowed a gauge.
I never thought to check spark at lower throttle since it was working in the upper range. I'll give it a look tomorrow. What would cause the spark to fail at lower throttle?
Btw this is my first venture into small gas engines so thanks for your patience.. I'm better with the bigger ones!
oldboat1
agree with the above. Did you do any work on the magneto (points and coils)? In the late '60s, they went to a portable tank along with the integral one, and that would have involved a fuel pump, which could be your issue if running on the separate tank. Since spraying into the carb doesn't help, though, sounds more like ignition or compression.
F_R
Honorary Supreme Mariner
If you haven't looked at the ignition system, you need to. If the coils haven't already been replaced, they probably are cracked and junk.
Not that this applies to yours, but I had one that drove me bonkers. I finally figured out that somebody had it apart and installed the pistons backwards. Point is, don't assume.
boomzilla
I had the lid off replacing the pull cord and I did see that the coils are due for replacement. That part of the setup is pretty alien to me. I'll have to watch some youtube videos until I understand how it works.
Thanks for all the advice. I have some good leads to work on now. I guess I'll tackle the magneto first since I know it needs work.
oldboat1
Work on half the magneto at a time so you can easier get the assembly correct (coil/points/condenser.) Points and condenser are on the right of the coil to which they "belong."
lindy46
Did you install a carb kit, or just "blast" down the throat of the carb without taking it apart? You need to remove the plug on the top of the carb and clean out the cavity and passages beneath. And make sure the tip of the slow speed needle isn't broken off in the orifice where it passes.
