MTboatguy
- Jul 8, 2010
- 8,988
Re: Lighting a propane fridge
Actually the valve is open in your first picture, the valve is open when handle runs parallel to the propane line, or at least it should, unless someone has made a modification along the way. As far as a regular fridge, should not be a problem if you can find one to fit the hole, take into mind you will have to run electricity for a regular fridge or run an extension cord in through the outside access.
Just to add, in looking at the pictures closer, I stand corrected, that is a 2 way fridge, the wires on the left hand side of the picture are the 110v wires that go to the heating element in the fridge, so it will run on 110v electricity as well.
the switch is set to off in that picture. Would a standard sized dorm room fridge fit in that opening? cause if it would I would just remove the old one and use it
