TBarCYa
- Apr 13, 2005
- 781
Re: Light a match and watch it burn? PLEASE help... at a lose and it grew on me
Dave,<br />It's a 1985 90HP Evinrude that idles fine but won't accelerate past half throttle. Originally, the #1 cylinder wasn't running at all and once I replaced the reed cage gasket and intake manifold gasket, the #1 cylinder started to get fuel. I took the boat out for the day and it was great for the first hour or so and then it started to act badly again. That's when I removed the black cover from the carbs and noticed it spitting fuel back at me from only the one throat. I retorqued the head bolts on the water and it ran better for a short time but acted badly once again. <br /><br />I'm replacing my head gaskets and checking to make sure the head is not warped plus I'm planning to swap that reed block with one from another cylinder to see if the spitting moves. Other than eliminating the head, head gasket, and reed valves, I don't know of any other way to diagnose a broken crank ring. I have an engine with a broken ring and it's not pretty.
