lifting points on Yahama 130
revsay
I want to remove my Yahama 130 from my skeeter. I have been told, by a Mechanic there are two lifting rings on the head. I can only find one just behind the flywheel cover. Do I need to remove the flywheel and attach a special ring to lift the engine?
Thanks for your input.
Tom
99yam40
Re: lifting points on Yahama 130
Posting your model # and pics may help people identify your motor and the lifting points.
You should not have to pull the flywheel
boatguy823
nope....only 1 and its located on top of the powerhead between the heads
