Is the cap strong enough to hold the weight of the entire boat? I'm trying to figure out how to most easily get at the hull to paint it, but obviously the trailer is a little bit in the way. If strong enough I was thinking about adding side to side 2x4 blocking inside the hull fitted underneath the turned down lip of the cap and then hoisting it in the air. Supports would be placed underneath of course in case the boat were to drop. Naturally I would like to paint the hull at once instead of lifting one end at a time or shifting around on the trailer to paint piecemeal.
Thanks
Thanks
