Let's Leave The Log There, So EVERYONE Hits It!
jay_merrill
I have a few recreational crab traps and go out every few days to bring some supper home. Last night, as I was on my way to them, a pair of boats were being towed in by another pair of good samaritan boaters. The folks aboard each, warned me of a large log a couple of miles down the bayou, which was masked by our ever present, summertime water hyacinth infestation.
When I got to the area involved, I pushed through the lillies slowly, but never did see the log. Because of this, I just continued on to my traps, where I harvested about three dozen crabs.
On the way back, I met another boater head-on, as he threaded his way through the lillies. They can get extremely thick - so much so, that people try to cut through them in places where other boats have recently passed, creating a narrow "lane." In this case, the lane was narrow for most of its length, so I found a bit of an open area and stopped, so that the other boater could get by. Sure enough, BAM! The guy hit it. He wasn't going very fast, so it wasn't a big deal, but he did say that it was the second time he had hit it yesterday.
Apparently, this had been going on all day and no one seemed to think it prudent to tie a line to the log and remove it! The two boats that I saw being towed in must have hit the log at high speed, which is kind of dumb, because these floating islands of lillies often do have logs trapped in them. Both were late model outboards and both apprently sustained enough damage to prevent them from running properly. So, at least two motors that I know of "bit the dust" ..... or log, as it happened to be! Since it was about 5:00 pm when I saw these guys, I have to wonder how many other motors got beat up earlier in the day!
Even now, as I write this, I can only shake my head as I think of how many people could have towed the darned thing out of the way. I was going to do this the first time I went by it, but couldn't find it in the lillies. On the way in, however, I could see it because of the other boater hitting it. I let him get clear, moved up to the log, tied a line around it in a choking loop, cinched it up along side my boat and made the line fast the one of my rail cleats.
As I got it moving a little bit, the log rose up out of the water, allowing me to see all of it for the first time - it was about 20 feet long! I towed it all the way back to the boat ramp, secured it to a dock and then pulled it out of the water, by tieing the line to the back of my boat trailer, before I retreived the boat.
How amazing is it, that boater after boater, would leave a 20' log in the middle of a waterway, knowing that others will hit it, just like they did? I don't know if this is pure laziness or just stupidity, but it sure makes me think some folks need to get a clue!
:confused: :confused: :confused:​
robert graham
Re: Let's Leave The Log There, So EVERYONE Hits It!
You did a good deed, but it must not even occur to most folks that they are even able to remove a log or how to go about doing it. I've never moved one, but after reading your account, next time maybe I'll just rope that big ugly sucker and drag it off! Folks learn stuff!
kenmyfam
Many folk won't care because they have passed it and will leave it for others to take care of !!!. Bad idea I know but many folk are like that. Pulled a couple in myself over the years when I have come across them.
Good Job !!!! many folk will unknowingly be thankful for what you did.:)
Home Cookin'
last weekend I pulled a traffic barricade out of the harbor. Don't know what to do with it.
I pull stuff out all the time.
Shamus O'toole
if that logs been in the water for a long time it could be worth money. These old waterlogged logs make awesome furniture!
lncoop
I was just thinking that. He should contact the Swamp Man from History Channel's Axe Men.
RicMic
A good friend on mine built a house on a pretty little bay and since he was on the water, bought his first boat, a pontoon, well right in the middle of this bay is a huge log, so my friend tells his neighbor that they should tow the log out of the bay, both of them tie short ropes to the log and start towing it out of the bay, well the water started getting deeper, fast, and the log went right to the bottom, the neighbor panicked and untied his rope, the log anchor nearly stood my friends pontoon straight up, because the rope was so tight that he couldn't untie it and it took him a while to saw through the rope with a dull penknife!
jay_merrill
The trick is to take a double "turn" around the log with your line. That will cause the loop to tighten around it and grip well enough for towing.
Pilings and other items with a smooth, regular shape to them, can be towed behind the boat, as long as the attachment point is near the end of them, causing the "nose" to rise as it moves through the water. This method doesn't always work with waterlogged trees, however. They sometimes want to dive towards the bottom, so you have to take them in a sidetow, with the nose of the log pulled up as far out of the water as you can get it.
As for logs that want to sink and other problems associated with them being made fast to the boat - that's why I keep a very sharp fishing knife in the glove box of my boat. I also have a seaman's folding knife, which I often wear on my belt.
Bill Kilgore
Dang that scared me and I was not even there! I assume that was what some would call an "elevated" pucker factor.
26aftcab454
I once saw a huge log floating in the middle of 8mile long x 2 mile wide Lake Grapevine -I was in my old LoneStar and pushed it 10 min to the bank- I crusie at night all the time and would hate to have hit it. If you do not do it who else is going to?
EddiePetty
....the James River, in the vicinity of the JRB, Monitor-Merrimack or Hampton Roads Bridge Tunnel are terrible for large debris after inland storms. Rare is the day that the XO and I don't pull at least one navigational obstacle out of the water.....largest to date was a 4" x 12" x 6 foot wooden beam that took three of us to get onto the swim platform. That thing laid next to the trash receptacles at Huntington Park all season!!
On our inland rivers, locals are in the habit of marking submerged, partially floating or drifting obstacles with a length of line and an empty, capped, plastic beverage bottle. In the vacinity of Courtland, the Nottoway River has one especially crooked stretch that is marked with dozens of those bright little survey flags.
itsaboattime
I run the Rock River alot. There are about 5 whole trees in the stretch that I run. All marked with empty antifreeze jugs or 5 quart oil jugs. They are all just too big to pull out of the river.
Jay you did the right thing. Heck I give ya credit for just boating in water that has Croci-gators in it. LOL.
jay_merrill
Aw shucks - they only bite ya, while you are tieing a line around a log! ;)
