LubeDude
Thread starter- Joined
- Oct 8, 2003
- 6,945
OK, to start off, it`s a 1996 Stratos 295 Pro XL, 19 1/2' with a 3 ltr Johnson Limeted Edition 200 HP. I have all but confermed that the true HP of this engine is 225.
I have only rung it out one time without a GPS and the boat speedo says 68-69 MPH @ 5,900 RPM Fully tournament loaded and two people and fully trimmed out with the roostertail lower than the cowling and no more to go. I`ve ordered trim exteders. The boat has a manual Jack plate , not sure if it`s an 8 or a 6". I havn`t measured the hight yet. It`s high though because the top water holes on the lower unit have been epoxied shut. The prop is an older Raker [which I have heard are better than the new ones] 14 1/2 X 26P. I have a set of the new plastic Smart tabs but havn`t installed them yet.
I loved the Scorpion that Walleyehed loaned me last year. I have never seen a prop with as much bow lift as that prop had. But, because of the large amount of rake and the 15" size, I`m unsure as to which pitch I will need. I had a 25 Scorpion I think and I was running a 25 High five at 5,700 RPM. The Solas dropped me to around 5,200. The Solas was about 2" larger but the same pitch. A 25 Scorpion might drop me too much, but I could raise the engine some more with it. The Turbo Lightning in a 14 3/4 X 27 Might just be the ticket. Anyone have one I could try?
Everything I do to the set up will be listed in this thread.
I know this boat has 70+ MPH in it with the right set up.
