Definitions A - L
Definitions A - L
Definitions of Terms
A
ACCELERATOR?Additive that reduces gel and cure time of
thermosetting plastics such as polyester gel coat and resin.
Also called promoter or activator.
ACETONE?in the context of FRP, primarily useful as a cleaning
solvent for removal of uncured resin from applicator
equipment and clothing. VERY FLAMMABLE LIQUID.
ADHESIVE?Material that unites two surfaces.
ADHESIVE FAILURE?Failure in an adhesive joint that occurs
between the adhesive material and the adherend; contrast
with Cohesive Failure.
ADDITIVE?Substance added to resin mix to impart special
performance qualities, such as ultraviolet absorbers, and
flame retarding materials (waxes, accelerators, etc.).
AIR-INHIBITED RESIN?Resin which cures with a tacky surface
(air inhibits its surface cure).
B
BAG MOLDING?Technique in which composite material is
placed in rigid mold and covered with flexible bag. Pressure is
applied by vacuum, autoclave, press, or by inflating the bag.
BENZOYL PEROXIDE (BPO)?Catalyst used in conjunction
with aniline accelerators or where heat is used as an accelerator.
BI-DIRECTIONAL?Arrangement of reinforcing fiber strands
in which half the strands are laid at right angles to the other
half; a directional pattern that provides maximum product
strength to those two directions.
BINDER?Bonding resin applied to glass fibers to hold them
in position in a broadgoods textile structure. During lamination,
this resin is dissolved by the styrene in polyester resin,
and, if unsaturated, can become part of the final polymer
network.
BINDERLESS CHOPPED STRAND MAT?Textile material
consisting of short glass fibers held together with polymer fiber
cross-stitch; resembles chopped strand mat without the
binder. Also called Stitched Chopped Strand Mat.
BLEEDER CLOTH?Layer of woven or nonwoven material
(not part of composite) that allows excess gas and resin to
escape during molding process.
BLEEDING?Result of softening of backside of gel coat (typically
by laminating resin, or post applied gel coat) which
causes pigments (color) to reflow.
BLEED OUT?Excess liquid resin appearing at the surface,
primarily occurring during filament winding or from an RTM
mold tube.
BOND STRENGTH?Stress required (as measured by load/
bond area) to separate a layer of material from another material
to which it is bonded. Also, amount of adhesion between
bonded surfaces.
BRIDGING?Condition that occurs when textile or sheet
material does not conform to inside edge or radius on mold
or laminate surface.
BUCKLING?Failure mode usually characterized by fiber
deflection rather than breaking.
BULK MOLDING COMPOUND (BMC)?Premixed blend
of thermosetting resin, reinforcements, catalysts and fillers
for use in closed molding process. Similar to sheet molding
compound (SMC), but mechanical qualities are not as good
and it is less expensive.
C
CARBON (OR GRAPHITE) FIBER?Reinforcing fiber known
for its light weight, high strength, and high stiffness.
CARBOXYL?Chemical group characteristic of organic acids,
which are incorporated into the polyester reaction process.
CAST POLYMER?Non-reinforced composite (resin used
without reinforcing fibers). Combines polymers, fillers and
additives as composites to meet specific applications requirements.
CATALYST?In scientific sense, substance that promotes or
controls curing of compound without being consumed in
the reaction (initiator). Within the composites industry, free
radical initiators such as MEKP are often referred to as ?catalysts.?
Such usage is scientifically inaccurate since initiator is
consumed during usage.
CATALYST (PEROXIDE)?In FRP terms, substance added to
resin or gel coat in controlled quantities to make it gel and
cure. Catalyst is reduced by accelerator, creating free radicals,
which in turn initiate polymerization.
CHALKING?Dry, powder-like appearance or deposit on
exposed gel coat surface.
CHOPPED STRAND?Uniform lengths of fibers formed by
cutting continuous strand yarn or roving, usually from 1/32
to two inches long. Lengths up to 1/8 inch are called milled
fibers.
CHOPPED STRAND MAT (CSM)?Uniform lengths of fibers
held together by binder and added to increase composite
part glass skin thickness. Relatively inexpensive, generally
used with other glass mats.
CLOTH?Fine weaves of woven fiberglass.
COBALT?Used as accelerator for methyl ethyl ketone peroxide
catalyzed polyesters.
COHESION?Tendency of single substance to adhere to itself.
Also, force holding single substance together.
COHESIVE FAILURE?Failure of adhesive joint that occurs
either within adhesive material or within one or both adherends.
COMPOSITE?Material that combines fiber and binding
matrix to maximize specific performance properties. Neither
element merges completely with the other.
COMPRESSION MOLD?Mold that is open when material
is introduced and that shapes material by heat and by the
pressure of closing.
CONTACT MOLDING?Open-mold process that includes
spraying gel coat, followed by hand layup or sprayup with
glass and resin. Also called open molding.
CONTINUOUS FILAMENT MAT (CFM)?Textile material
comprising continuous fibers, typically glass, that are swirled
randomly in a construction with more loft than chopped
strand mat for the same areal weight.
CONTINUOUS FILAMENT STRAND?Individual fiber with
small diameter, flexibility and indefinite length.
CONTINUOUS LAMINATING?Process for forming panels
and sheeting in which fabric or mat is passed through resin
dip, brought together between cellophane covering sheets,
and passed through heating zone for cure. Squeeze rollers
control thickness and resin content as various plies are
brought together.
CONTINUOUS ROVING?Parallel filaments coated with sizing,
gathered together into single or multiple strands and
wound into cylindrical package. May be used to provide
continuous reinforcement in woven roving, filament winding,
pultrusion, prepregs, or high-strength molding compounds.
(Also see ?Chopped Strand.?)
CORD, REINFORCING?Loosely twisted cord made up from
rovings and designed for incorporation in moldings where
edge reinforcement and high strength ribs are necessary.
CORE?(1) Central component of a sandwich construction
to which inner and outer skins are attached; common core
materials include foam, honeycomb, paper and wood. (2)
Channel in mold for circulation of heat-transfer media. (3)
Part of complex mold tool that molds undercut parts, also
called core pin.
CRAZING?Cracking of the resin due to internal stress.
CROSS-LAMINATED?Laminated so some layers are oriented
at right angles to remaining layers with respect to
grain or strongest direction in tension.
CURE?Polymerization or irreversible transformation from
liquid to solid state with maximum physical properties, including
hardness.
CURE TEMPERATURE?Temperature at which material attains
final cure.
CURE TIME?Time required for liquid resin to reach majority
of polymerized state after catalyst has been added.
CURING AGENT?Catalytic or reactive agent that initiates
polymerization when added to resin; also called ?hardener.?
D
DELAMINATE?Separation of layers due to failure of adhesion
or cohesion of one component to others. Also includes
separation of layers of fabric from core structure. May be
associated with bridging, drilling, and trimming.
DELAMINATION?Laminate defect that occurs due to mechanical
or thermal stress and is characterized by separation
between laminae.
DIMENSIONAL STABILITY?Capability of substance or part
to maintain its shape when subjected to varying forces,
moments, degrees of temperature and moisture, or other
stress.
DIMETHYLANILINE (DMA)?Accelerator used in conjunction
with BPO catalyst; more effective than DEA.
DIMPLES?Small sunken dots in gel coat surface, generally
caused by foreign particle, air void, or catalyst droplets in gel
coat or laminate.
DOUBLER?Extra layers of reinforcement for added stiffness
or strength where fasteners or other abrupt load transfers
occur.
DRY SPOT?Laminate defect that occurs during molding
process and is characterized by dry, un-wet fibers that have
never been encapsulated by matrix material.
E
EDGE?Geometric feature characterized as line formed
where two panels on different planes come together. When
angle between two panels is between zero and 180 degrees,
edge is inside. When angle is between 180 and 360
degrees, edge is outside.
E-GLASS?Electrical glass; refers to borosilicate glass fibers
most often used in conventional polymer matrix composites.
ELASTICITY?Capacity of materials to recover original size
and shape after deformation.
ELASTIC LIMIT?Greatest stress material is capable of sustaining
without permanent strain remaining after complete
release of stress.
ELONGATION?Increase in length of section under tension
when expressed as percentage difference between original
length and length at moment of rupture.
ENAMEL?Gel coat or surface coat which cures tack free.
ENCAPSULATING?Enclosing article in closed envelope
of plastics) by immersion. Milled fibers or short chopped
strands are often poured with catalyzed resin into open
molds for casting electrical components.
END?Strand of roving consisting of given number of filaments
is considered an end before twisting.
END COUNT?Exact number of strands contained in roving.
EXTENDERS?Low-cost materials used to dilute or extend
higher-cost resins without excessive reduction in properties.
F
FABRIC, NONWOVEN?Material formed from fibers or yarns
without interlacing, (e.g., stitched nonwoven broad goods).
FABRIC, WOVEN?Material constructed of interlaced yarns,
fibers or filaments.
FABRICATION?Process of making composite part or tool.
FATIGUE?Failure of material?s mechanical properties
caused by repeated stress over time.
FATIGUE STRENGTH?Maximum cyclical stress withstood
for given number of cycles before material fails.
FADING?Loss of color in gel coat.
FIBER BLOOMING?Fiber and resin are eroded by weathering
or sandpaper at different rates. Resins erode before
fiber. As a result, fiber rich surface, when sanded, often has
fibers protruding; called fiber blooming.
FIBER CONTENT?Amount of fiber in composite expressed
as ratio to the matrix by weight.
FIBER ORIENTATION?Direction of fiber alignment in nonwoven
or mat laminate; most fibers are placed in same direction
to afford higher strength in that direction.
FIBER REINFORCED PLASTICS (FRP)?General term for composite
material or part that consists of plastic matrix containing
reinforcing fibers such as glass or carbon having greater
strength or stiffness than plastic. FRP is most often used to denote glass
fiber-reinforced plastics. ?Advanced composite?
usually indicates high-performance aramid or carbon
FIBERGLASS?Fibers similar to wool or cotton fibers, but
made from glass; sometimes call fibrous glass. Glass fiber
forms include cloth, yarn, mat, milled fibers, chopped
strands, roving, woven roving.
FLEXURAL STRENGTH?Strength of material (in bending)
expressed as stress of bent test sample at instant of failure;
usually expressed in force per unit area.
FRACTURE?Rupture of surface of laminate due to external
or internal forces; may or may not result in complete separation.
FRP?Fiber Reinforced Polymers; with evolution of new fibrous
materials, GRP (or GRFP) becomes Glass Reinforced
Polymers term.
FUMED SILICA (Aerosil, Cabosil)?Thickening agent used in
polyesters to increase flow or sag resistance qualities.
G
GEL?Partial cure stage in plastics resins of a viscous, jellylike
state where liquid material starts to transform into solid.
GEL COAT?Surface coat, either colored or clear, providing
cosmetic enhancement and protection for the laminate.
GEL TIME?Length of time that catalyzed polyester remains
workable after hardener is added.
GELATION?Transition of liquid to soft solid.
GENERATION?Term used to describe single step in progression
from concept to master mold to production mold
when molding composite parts with multiple molds from
same pattern.
GLASS TRANSITION?Reversible change in amorphous
polymer between viscous or rubbery condition and hard,
relatively brittle one.
GLASS TRANSITION TEMPERATURE (Tg)?Approximate
temperature above which increased molecular mobility
causes a material to become rubbery rather than brittle.
The measure value of Tg can vary, depending on the test
method. (A widely accepted method is Differential Scanning
Calorimeter?DSC.)
H
HAND LAYUP?Laminating by ?hand? as opposed to using
spray equipment. Usually requires mat and fabric reinforcements
in sheet form.
HARDENER?Substance that reacts with resin to promote or
control curing action.
HEAT?Term used colloquially to indicate any temperature
above ambient (room) temperature, to which part or material
is or will be subjected.
HEAT-CONVERTIBLE RESIN?Thermosetting resin convertible
by heat to an infusible and insoluble mass.
HEAT-DISTORTION TEMPERATURE (HDT)?Temperature at
which test bar deflects certain amount under specified load.
(e.g., temperature at which material softens).
HEAT-PRESSURE LAMINATES?Laminates molded and cured
at pressures not lower than 1000 psi.
HELICAL?Ply laid onto mandrel at an angle, often 45 degree
angle.
HERMETIC?Completely sealed, air-tight.
HONEYCOMB?Manufactured product of sheet metal or
resin-impregnated sheet (paper, fibrous glass, etc.) that has
been formed into hexagonal shaped cells. Used as core
material for sandwich construction.
HOOP?Ply laid onto mandrel at 90 degree angle.
HOOP STRESS?Circumferential stress in cylindrically
shaped part as result of internal or external pressure.
HOT POT?Catalyst is mixed with gel coat or resin in material
container prior to spraying, as opposed to internal or
external gun mixing.
HYBRID COMPOSITE?Composite with two or more types
of reinforcing fibers. Also refers to composite prepared from
a polymer which uses more than one type of chemistry, such
as XYCON? polyester/polyurethane hybrid material.
HYBRID RESIN?Resin with two or more types of chemistries
combined.
HYDROPHOBIC?Moisture resistant capability, moisture repelling.
HYGROSCOPIC?Moisture absorbing capability.
I
IMPREGNATE?Saturation of reinforcement with a resin.
IMPREGNATED FABRIC?See ?Prepreg.?
INCLUSION?Physical and mechanical discontinuity occurring
within material or part.
INHIBITOR?A substance designed to slow down or prevent
chemical reaction; chemical additive that slows or delays
cure cycle.
INJECTION MOLDING?Method of forming plastic to desired
shape by forcibly injecting polymer into a mold.
INTEGRAL HEATING?System in which heating elements are
built into a tool, forming part of the tool and usually eliminating
need for oven or autoclave as heat source.
INTERFACE?Surface between two materials in glass fibers,
(e.g., area at which glass and sizing meet). In laminate, area
at which reinforcement and laminating resin meet.
INTERLAMINAR?Existing or occurring between two or more
adjacent laminae.
INTERLAMINAR SHEAR?Shearing force that produces displacement
between two laminae along plane of their interface.
ISOTROPIC?Arrangement of reinforcing materials in random
manner, resulting in equal strength in all directions.
J
JACKSTRAWING?Prominence of fiberglass pattern having
turned white in the laminate because glass has separated
from resin due to excessive exothermic heat; usually associated
with thick, resin rich laminates. Cosmetic problem
only.
K
KEVLAR??Strong, lightweight aramid fiber trademarked
by Dupont; used as reinforcement fiber.
L
LAMINA?One layer of laminate; can be chopped fiber reinforced
plastic layer, textile reinforced plastic layer, or core
material, etc. Plural is laminae.
LAMINATE (noun)?Panel that consists of multiple laminae
that are permanently bonded together.
LAMINATE (verb)?Action of manufacturing laminate (noun)
by arranging one or more laminae. In FRP, each lamina usually
consists of a fibrous reinforcement and a resinous matrix
material.
LAMINATED PLASTICS?Material consisting of superimposed
layers of synthetic materials that have been bonded
together, usually by means of heat and pressure, to form
single piece.
LAMINATION?Laying on of layers of reinforcing materials
and resin, much like buildup of plywood. Several layers of
material bonded together.
LAYUP?Placing reinforcing material onto mold and applying
resin to it; can be done by hand or by using sprayup
equipment. Layup is sometimes used as a term for the work
piece itself.
LOW-PRESSURE LAMINATES?Laminates molded and
cured in range of pressures from 400 psi down to and including
pressure obtained by mere contact of plies.
LOW PROFILE?Resin compounds formulated for low, zero,
or negative shrinkage during molding.
Information supplied by ondarvr .
