Ob1415
- Mar 15, 2011
- 71
And so the saga continues.....
After picking up my brand new 2011 Glastron GT 205 from having the motor swapped, the stereo did not work.
I found that it was a bad harness. I brought the boat back to the dealer amd they decided to eliminate the harness and hard wire the stereo. Sounds simple enough, right? WRONG!!!
They assured me that they completed the repair and tested everything and that everything is now working fine. They dropped the boat off at my house. When I got home from work, I hopped in the boat toconfirm all was working. I flip on the stereo, it plays for all of 5 seconds, then dies. I check the vent an bilge pump toggles...no power. I turn the key...no power. I open the engine bay and find that 2 of the fuses blew out. I look at the bottom of the bay and see several blown fuses scattered about.
This tells me that they knew there was an issue and returned the boat to me anyway!!! WTF?
I called them this morning and demanded that they come pick up the boat and that they either give me another brand new boat or refund my $ and I will purchase another boat elsewhere. They said they would pick it up amd look at it. Advised them to look all the want, but I will not take this boat back as the safety and reliability has been compromised and that I have no confidence in this boat to take my family out onto a lake in it. Advised them that boats are covered under the Magnusson Moss Warranty Act in TX and that I will go that route if necessary. He said that, that would not be necessary as they intend to "make it right".
They picked up the boat and said they would call me soon to discuss the solution. We'll see what happens...
