Cricket Too
- May 14, 2003
- 1,732
Just wanted to ask a quick question about troubleshooting the lean sneeze my 2000 200hp Johnson has developed.
I was going to start by looking for an air leak along the fuel lines. This is made a little easier by the fact that there are twin engines on the boat and the other one has no lean sneeze. So at least I know I don't have a problem from my tank to where it branches off to the two separate water separators.
It occured to me that there is a fuel restriction warning on the newer style system check gauges, and I know it works on mine. So I was wondering if I had enough of an air leak in a fuel line before the OMS pump, would it set off the fuel restriction warning horn??
If this is possible, then I could maybe narrow my search down a little, as I would only have to check from the output of the pump to the carbs, and also inevitably my carbs. I gotta get this taken care of, the fall bass run is on and I don't want to smoke an engine while I'm out there.
So is it possible for an air leak before the OMS pump to set off the fuel restriction warning?
Thanks, Mike.
Thanks, Mike.
