Leaky shift bellows
Onexl85
pulled my alpha one g2 today and had some sludge come out of where the shifter sticks out of the bell housing. Leaky shift bellows?
could be. when was the last time you did a bellows and gimble bearing replacement?
Onexl85
Just bought the boat, what else could it be?
If you just bought the boat, replace all rhe bellows, rhe raw water pump, gimble bearing,etc
Onexl85
Just ordered the kit, Thanks Scott!
Onexl85
Does the area where the sleeve that grabs the outdrive linkage from the bell housing take on water normally? Seems like there’s no gasket keeping water out
Nope,.... It's a rather snug fit, which don't usually leak,....
I use opposin' zip-ties, rather than the provided crimp-ring,....
'n if you insist on the trim limit, 'n trim sender workin', I suggest ya change them as well,....
The wires tend to rot off,.....
Onexl85
I wound up breaking the fitting for the oil resivoir at the transom. I was able to Bull the eclip from inside the boat but the darn fitting won’t pull out! Any suggestions?
Onexl85
Wound up getting it out......I drilled a hole thru it then used a piece of 1/4x 20 threaded rod to extract! Wish I could post a pic from my I phone for others to see.....every time I try to post a pic the file is too big
