Leaking tilt/trim ....stumbled upon a fix (probably temporary)
crazy charlie
New to me 2000 Yamaha 200hp saltwater series .I checked out the Grady white Adventure that it is hanging on from stem to stern and bought it.What I missed is a very slight trim fluid leak.Veeeeery slight or possibly intermittent but slight. Thought I had some trim fluid to top it off but I didn't. What I had nearby was a bottle of Bars bottle jack oil /fluid with leak stopper.Since my trim hardly needed any fluid to top it off I figured what harm could it do to use it.Took maybe an ounce or 2 tops.To my surprise the unit no longer leaks.It has been a few months so I cant believe it is cured(Lol) .Just thought I would share my experience in case it can help someone else make it thru a season without having to make a mid season repair it is worth a try.This post is not meant for some of our overanalysts on this forum that ALWAYS have to add their 2 cents and state " This is not a fix and the repair should be made correctly" so those that know who you are just read this for what it is worth and I hope it helps someone get a little more distance out of their tilt unit .
