Leaking Tilt Jack?
trawkins
I usually tow and store my outboard in the tilted position (on the tilt legs). While doing other work, I noticed for the first time red hydraulic fluid leaking from the jack while in the lowered/running position. I wiped it off to get a clue on flow rate, and it returned (very slow leak) next time I dropped the motor. Is this just an issue with seals? If figure that a leak would most likely occur in the pressurized/tilted position, but I’m certainly no expert. Johnson 2005 50 2stroke J50PLSOC
You can usually get seal kits for PTT units. You will need or need to fabricate a spanner to open the tilt cylinder.
BTW, you should clean, prime and paint that PTT motor, or it will rust out.
emoney
Those seals definitely go bad that's for sure. Not a horrible job, just need a spanner wrench.
