swordfish25
- Mar 18, 2009
- 117
Picked up a 78 starcraft alumn. 14 ft open fishing boat, and the rivetts are leaking mainly the ones that hold the ribs on. Is it possiable to repean the same rivetts,or do I have to replace them , if so do I have to put some kind of sealer on them before I do? It would not do any good to paint galvet on the inside, because you could not get it under the ribs. Seems like most of the leaks are on the starboard side, first three ribs. This is the side I sit on and gets the most pounding. I would have to grind or drill out the rivets to take the seats out to get at some of these. Has anyone tried stove bolts insterd of rivets. With sealer and locktite, washers on nuts side ? Is there a special tool for doing the rivets ? I assome it is a two man job, one on top, and one on bottom. I am open for advice on this project. The boat is in excelent shape otherwise .
