FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I went out to check my boat this spring and noticed oil on ground under motor after futher servey oil was coming from crack just below fill holes for gear oil on lower unit can any one tell me what happend 1989 85 hp force
The crack you mentioned is the scary part. Did you drain and refill the lower unit last fall? If not was the motor in an area that can freeze? If so you may have had water in there and it expanded when it froze and cracked the lower unit.
If you know of a GOOD welder, drain the oil and take it to him for repair. Make sure you tell him that the aluminum is a high silicon content alloy. Makes a difference when welding.
If not, look for a good used unit on one of the auctions. If oil is leaking out of a crack, water will most certainly get in.
Just asked a good friend about it who is a Cert welder and he said if you cant find a welder to try any Machine shop because they would have more experience in wielding aluminum. (Car heads and such).
I did not refill the lower unit and I am in an area that can freeze.What do you think about welding the 1 and a half inch crack. I know someone who told me that the gears get out of alinement sometimes when the case cracks any help would be appr
The upper drive shaft bearing is right at this area. From your description it sounds like the crack is right at the spot where the outer race seats in the case. At this point, rather than trying to diagnose what has happened, my advise to you is to drop the lower unit, remove the complete water pump assembly and see what problems developed in this area to cause the crack.
The drive shaft will not come out until the pinion is removed so it may also be necessary to remove the gear pak to see the condition of the upper bearing and race.
