Leaking fuel!
Jimidude87
Hey guys i have a 1986 Chaparral 204 with a johnson 150 on it. This is a new to me boat and the gas tank was not in it when i got it. I just got the tank from the previous owner and installed it about a month ago.
I took the boat out 2 weekends ago and it ran great with the new tank...after a couple short minutes i noticed a strong gas smell so ended my trip early. I got back and pulled the fuel tank back out and noticed a good amount of fuel under the tank.
I examined the tank and saw some small pin holes in it. I bought an epoxy repair kit with had epoxy and a fiber glass cloth. I repaired the pin holes (maybe 3 of them. Put the tank back in an tried again last weekend. Got it out and after about 30 minutes i noticed a gas smell again so brought her in. I believe the fuel filler hose needs to be replaced and am going to just buy a new gas tank.
My question is does anyone have any experience replacing the filler hose on one of these boats? It goes under the floor and then out through the starboard side. Can this be replaced without cutting anything? I tried to pull it out before with no luck. Also does anyone know where i can get a replacement tank for that year/model? I've looked all over great lakes skipper, cecil marine, and many other online sites but can only seem to find "universal" tanks.
Any help is greatly appreciated!
Chris1956
Honorary Supreme Mariner
Replacing the fuel tank is the right call. If a tank has 3 pin holes, it will likely have more pin holes in short order, as more of the tank material corrodes away.
