Leaking from...weepholes???
MrSdnuop
I have a leak coming from each side where these holes are. The one in the picture right below the bolt. Is this normal? What fluid is it? Where can I check the levels and out more in? I'm new to boating including servicing so any help will be greatly appreciated.
MrSdnuop
1992 Searay 200 with 4.3 Mercruiser
Bt Doctur
If its oil you have a leak and the res bottle would be showing low.
Your drive is a alpha gen ii type
