Kiwi Phil
Thread starter- Joined
- Jun 23, 2003
- 2,182
I have a dam with max holding capacity of 3.5million litres of water.<br />We have been in drought for around 5yrs, so the dam has not reached its overflow level.<br />About 3/4's way up the wall a leak in 1st yr of drought. <br /> It has started from the clay wall drying out, and remaining dry for long periods.<br />When I get a storm come through, it does fill, then empties to this 3/4 level quickly.<br />I can not see a crack, nor can I see leakage from the outside wall, as everything is wet.<br />It is built into the side of a hill, round with a "Turkeys Nest" type construction.( like an up side down cone on the inside.<br />Has any one ever had a similar problem<br />I can not afford a plastic liner.<br />I was told to spread a type of stock feed around the water line, for the leak to take it in to the space and plug it. One pallet later, and no change.<br />The top of the wall it too narrow for machinery (maybe 6-8ft wide).<br /><br />Cheers<br />Phillip
