Leak coming from Alpha Gen II
I went to launch my boat this am and noticed a fair amount of water coming from the housing up high near the steering. Is this at all normal?
Bt Doctur
Re: Leak coming from Alpha Gen II
Nope, not normal.shouldnt be any leaking anywhere
thinking it's the steering arm leaking, no evidence of any cracks in the driveshaft bellows or the shift bellows, would have been too low anyway. I will be replacing all three bellows for sure. Including the trim sender and limit switches. I did notice the set screw that holds the plastic end (engine side) is very rusty, any tricks on getting this screw out or is it going to require I replace the entire cable and sheath as an assy?
