Late 80s Johnson 40 hp dies under load
zsum
So not long ago, I bought a boat with a late 80s model Johnson 40 hp outboard. When I bought it, I tested it out of water, everything worked once I got it started, which took a bit, even when I put it in gear. But, once I took it out on the water and was ready to get going, when I tried to put it in forward or reverse, it start to sound bogged down and would die. Kept trying this for a bit with the same results. I've asked around to anybody that might know about boats and they all gave me a different answer or just didn't know, so here I am. Would love anybody's thoughts and advice since time is running out for the season and would love to get it on the water soon. Thanks!
Honorary Supreme Mariner
On land and " in gear " is really still nuetral as there is no load on the motor.-----It will start and run on one cylinder.-----Start with a compression test and a spark check.
valvebounce
Check the spark on both cylinders,if the compression is up to scratch,it will more than likely be gummed up carbs.strip and clean and blow through with carb cleaner.
zsum
Thanks for the tips! So I checked the spark, seemed ok, plugs are a bit dirty though. Then I ran a compression test, on the motor itself, someone wrote 130 by the top cylinder and 125 on the bottom. But when I ran the test, I got 70 on the top and 65 on the bottom. Any thoughts?
jakedaawg
Bad gauge. Cheap harbor freight guages do this. Rent a good gauge from an auto parts store if possible and try that. Or put your gauge on your car and see what you get.
Tim Frank
"Seemed OK"?
How did you test?
Best way is with an open-gap tester....set at 7/16". Spark should jump that cleanly.
If you just grounded the plugs, that is a non-test.
zsum
I rented the gauge from oreilys. I used an inline spark tester and according to the troublshooting manual, it read that the fuel system was most likely at fault
Sno
I would start it and after about a minute or so shut down and feel the base of each plug. Equally warm and both cylinders are firing. I would also try to resolve the compression test as I too suspect the gauge.
Old56
I had the same problem if your compression turns out to be ok definatly pull and clean the carb it sounds like your motor is starving for fuel. Who knows how well the seller took care of it,good luck
