Hey all, this is my first post as a member, but have been a background reader for a long time. I recently purchased a 21 deep vee Starcraft CC. It's got twin standard rotation 120's. As far as I've been able to identify they're anywhere from 88-94, but can't figure out a specific year or model number. There is no plaque or stamps on mounting bracket that I can see that help determine it either. Both powerheads have been replaced so numbers off plugs don't help. I do know that they're loopers and they have weep holes in lower units, not sure if that helps narrow it down.
I'm having problems getting to WOT revs on port side motor. Gets to between 2900-3200 rpm and starts acting like it's starving. I've gone thru the carbs, checked compression and spark. All seem good. I've messed with linkage at carb while running, no difference. Problem is only on port side motor. Starboard gets up to just under 5k rpm, while dragging other motor
Lastly, I have the vro eliminated, been disconnected and running premix since buying the boat. With these motors should the vro be replaced with an extra fuel pump when eliminated? Have had mixed reviews from people on that subject, and trying to find the truth behind it. Any help will be greatly appreciated. Sorry for being so long winded.
Matt
Matt
